This has happened to me many many times.... I dont knw wats wrong..Should we call the dealership???Colton92 wrote:Does anyone elses cruise control start accelerating after you set it? It has happened to me a couple of times after I pressed set, the speed just starts accelerating and does not stop until i press the brake.
that's pretty lazy to be setting CC at 25...Colton92 wrote:i got the gif off some guys sig on the general chat. The cruise control issue doesn't happen every time i set it. It preety much only happens when i set it around 25 or 30.
Thanks for the explanation that makes sense cause it only does this when i push (+) not when I push the set button.adidas2go wrote:You may be experiencing the resume feature of the curise control. It works like this.
You are crusing at 60 mph, and set your cruise control. Then you hit the brakes, and slow down to 25 mph. If you hit the (+) sign on the wheel now, the car will accelerate to the last speed the cruise was set to, 60. However, if you hit the cancel button, and reset the speed. It will stay at that speed.
Its happened to me when traveling 50+kuhan wrote:
Why are you using cruise control at 25-30 mph?????
Don't you know that's the lowest limit you can use cruise control and that can cause the problem. Try at high speed and see if the problem still exists.
