180fan »
https://forums.nicoclub.com/180fan-u3602.html
Wed Nov 12, 2003 4:40 pm
sounds like you didn't take off the two bolts holding the steering column in place. if you look under your dash, you'll see two 14mm bolts I believe. Once they come off, your column will come down and then you've got to take off the two or three screws holding the bezel part in at the top of it into the dashboard. Then you'll see another couple screws I think 3 more holding the cluster in place.
