defrag010 wrote:analask, YOU DA MAN!!!
Its anlasak, why so many members swap the "a" and the "l' I'll never know.
And to add to this, anyone who is using RTV to seal their valve covers will find a 1.5mm gap between the valve cover and head.
I'm using a custom valve cover gasket that measures 1.5mm compressed, unfortunately when I measured without the gasket installed, there is a gap.
There are 3 options as I see it:
#1: Make a gasket for the valve cover equaling 1.5mm or thicker #2: Drill 1.5mm deeper into the existing holes and tap for 1.0 thread (Dangerous due to water/oil passages and the proximity of the existing threads inside the hole to the actual open area you need to pass the drill bit through.)
#3: Shave 1.5mm off the tip off the bolt's threaded end
If anyone has any other suggestions please feel free to post.
