Silvia007 »
https://forums.nicoclub.com/silvia007-u255.html
Mon May 31, 2004 2:43 pm
It'll break once you bend it back and fourth to the point where it pinches, it'll then break at the pinch, if you bend it slightly all along the whole line to where you want it, you'll be fine. I've done 4 240's already, although I have not yet figured out what benefit this is, definately easier to bleed. That's about it, I kinda hate the vibration I get from the clutch pedal as I push it in. Ok, not so much as a vibration but you can feel like you're scrapping metal against metal as you push in the clutch.
