DAMN! reddish oil dripping from underbody..whats it from?
MarkEmark
Car: fully-built '95 240sx KA-T
I was lookin at the underbelly of my car today and noticed that a bit of red oil was forming droplets under one of the skidpads...now the oil wasn't dripping per say, but there were droplets, and it seemed like it was from the oil pan, but the drain plug was fine. I have no idea what kind of oil it was/where it was from. I checked my engine oil and the level was fine...this may sound like a dumb question, but is there manual transmission oil? my manual says NOTHING about it...my car shifts and drives fine, although the transmission has been pretty notchy lately when its cold (its always notchy, but it seems exceedingly notchy) So anyway, its a deep red oil...anyone know what thats from? I HOPE its nothing bad...thanks in advance
MikeS14240sx
Car: 98 Nissan 240SX
Well you can check the level of your transmission fluid. I would check that. Also check the level of your brake and power steering fliuids. Brake and steering fluid usually is a red color and may appear to be oil.
You should always check all your fluid levels anyways.
GodDrivesA240sx
Car: 1995 Nissan 240SX
If you have the 5yr antifreeze/coolant in your car it's a redish color, that could be it as well. It won't really be 'oily' per say but it's redish :) I would think it's transmission fluid though. See if you can smell it, if it smells like crap then its prob transmission fluid :)
SpeedingMonk
Car: drifting, nissans, and keeping all other cars behind me
ive only seen antifreez neon green could this red u mean be from rust +D an brake fluid ive never seen red brake fluid either aotimatic
anti freez - neon greenengine oil - clearish yellow (new brownish / black (used)brake fluid - clearish yellow too alot thiner thoAUTO transmission fluid - bright red (new darker shade (used)
manual transmission fluid is different but prob alot more red than n e thing else +D
auto trannys use hydrolics using the ATF to doo everything manual is differ tho
MarkEmark
thanks for the info..how the hell do i check my manual transmission fluid? There seems no dipstick for it...my power steering fluid looked dark green...
nismokid
i had the same problem, it was the power steering fluid
MarkEmark
so is the power steering fluid leaking from the actual pump, and if so, why/how would I remedy this? And again...how do I check the transmission oil? thanks
TrunkMonkey
Car: 2000 Lincoln Navigator
MarkEmark wrote:so is the power steering fluid leaking from the actual pump, and if so, why/how would I remedy this?
you need to check the entire system to find the leak (reservoir, pump, lines, ect...).
there's a plug on the driver's side of your transmission. remove the plug and stick your finger inside. the gear oil should be flush with the bottom of the hole.
GodDrivesA240sx
SpeedingMonk wrote:ive only seen antifreez neon green could this red u mean be from rust +D an brake fluid ive never seen red brake fluid either aotimatic
The 2 year antifreeze with no long time rust protection is neon green yes. There is an red/orange antifreeze. Havoline sells it, Zerxo or whatever sells it. It's the 5 year antifreeze that has long term rust protectants, and no siliconate somethings. Point is there is a such thing as red or orange or orange red antifreeze :)
MarkEmark
can i access this plug from the top or the bottom of the car? is it a screw in plug? thanks
TrunkMonkey
MarkEmark wrote:can i access this plug from the top or the bottom of the car? is it a screw in plug? thanks
you have to get underneath the car. it screws in, but i can't remember if it's an allen screw or socket.
y3llows14
when you go down there to check you transmission fluid, how do you replace the fluid after you drain it, and with what kind. Dauntt told me that it could be my transmission fluid that is why it is not going into reverse. Thanks. BTW is the gearbox oil the same thing or somewhere else? I heard people use Redline and it works great.
APEXi240
Car: 08 Nissan Versa S hatch
I have a similar question....I have an S14 and want to change the gear oil....I went under the car and couldn't figure out which bolt drained the fluid...I didn't want to pull out the wrong one, plus mosquitos were eating me alive, so I stopped. Which bolt would be greatly appreciated.
Sygerwulf
Car: 91 240SX SE
Yeah I have the orange antifreeze stuff. I freaked out when I saw it cuz I thought it was rust too lol
leper421
Car: Current: 2011 370z
Previous: 2003 350z, 1991 240sx
To change the MT oil, you have to remove the drain plug on the bottom of the transmission. Its a plug with a 1/2" square recessed into it. Use a 1/2" ratchet with no socket attached to open it. The refill hole is fairly high on the transmission and has a hex head bolt (dont know what size, I used a crescent wrench). You fill it with GEAR oil, not engine oil (I used 75W-80). I also found it much easier to pull out the shifter and add the oil through there then to get it in the filler plug. Either way you fill it untill it starts to drip out the filler plug.
y3llows14
So you just remove the shift knob and shifter and assembly and just add some gear box oil there? Thanx
leper421
You can do it without removing the shifter. Take all the boots off, and pour into the notch cut on either side of the ball pivot-point part of the shifter. It will take forever that way. It goes alot quicker if you remove the whole shifter assembly. Then just dump it down there.
Silvia007
Car: 93 Nissan 240SX SE Fastback
That orangish/redish coolant is called Dex-Acool. Made for new cars and loves to leave all sorts of gunk in the radiator if contaminated. Suppose to last 150k miles. As for filling, I recommend removing the fill hole as to not overfill. The gear oil can eat away transmission seals. When that happens, get ready to pull out some dough.
SRJesse
Car: Cars, hockey (roller and ice)
Check around your front suspension too. If your tie rod bushings have gone bad, they will leak some kind of fluid that nissans stock bushings had in them. Power steering fluid seems like the only other problem I could think of. Brake fluid is always clear, and yes 5 year antifreeze is a neon orange/redish color.
leper421
SRJesse wrote:Brake fluid is always clear
NEW brake fluid is always clear. When I bled new fluid through all my brake lines, the old fluid from the rear lines was dark brown. The front lines fluid was actually reddish brown, very similar to old ATF.
