OutToWinPAHC »
https://forums.nicoclub.com/outtowinpahc-u66900.html
Mon Mar 12, 2012 6:39 pm
The cylinder 3 gate drive signal to the coil pack is no good. It's there but very very low and out of spec where it should be about .15V on a scope it's about .02.
I contacted Apexi about sending my unit in for repair, they can do it, but the turn around time is 2-3 months.
Since the IC15 amplifier drive is bad, I thought I may try something.....
Does the RB fire two cylinders at once? If so I may try to run both transistors (coil packs) or that common drive signal and see what happens.
