progman »
https://forums.nicoclub.com/progman-u42503.html
Mon Dec 29, 2008 10:20 am
I'm no expert, but that code means that the CAS is dead or the wiring is bad/disconnected. same with the MAF.
If your CAS really is dead, your best bet is you buy a used CAS from someone here on the forum. You can use the one from a 1988 nissan pulsar. Those sell new from about 200-500 dollars. You can get a used CAS for around $50 dollars from the forums.
Double check your wiring. Undo whatever you did!!! I think you probably just bumped something. rare for the MAF and CAS to both get reported as bad by the ECU at the same time.
By the way the knock sensor is shielded and that shield (the stuff in the wire that is separate from the other wire in side the wire) should not touch the signal wire that goes to the knock sensor. Someone correct me if I'm wrong.
Modified by progman at 5:06 PM 12/30/2008
