Neil »
https://forums.nicoclub.com/neil-u15642.html
Wed Jun 25, 2008 8:52 pm
When a fuse blows, more current than the fuse can handle is flowing through the circuit. A short will definitely do that, but a pair of fans that draw 25 amps will also pop a 10amp fuse.
make sure your switch is rated to handle the current that the fans draw.. Also, whether the switch is on the ground wire or on the hot wire it still flows the same electricity.
personally i'd just cough up the $30 and get a thermostat switch and hook it up with a 30 amp relay so A) you don't have to wonder anymore and B) you don't have to manually operate it. If they are still running when you turn off the car, at least you know they'll turn themselves off in a very short while.
And NO, you DO NOT want to power your fans from another accessory like the wiper motor!!!
