Damn car squealing, getting hella tired of it..
Two Fowty
Car: 1990 240sx hatch, 1989 240sx hatch
Stupid car squeals when I start it up, and then it will randomly squeal when I'm driving. Usually starts squealing when I'm stopped at a stop light or in a drive thru or something, and then goes away after a while. It also does it when I slow way down to like 2mph and then put it in first and drive away.
The squealing pretty much comes back when I come to a stop anywhere, untill I've been driving for a while, and then the squealing is gone. I don't think it has to do with my engine temp cause the gauge is reading in the middle and it still squeals at times.
Pretty sure my belt is fine. I've tried it loose, and tight. No change. Frankly I can't stand this s*** anymore, its f***ing embarassing having it squeal hella loud plus sitting a minute after I start the car up, just for the squeal to stop. I've also tried to lube up the pulleys, and spray the belts with stop squeak stuff.
I read somewhere about the squealing being throw out bearing related? Didn't really make sense, but I thought I'd ask incase thats a possibility. I'm thinking of replacing the water pump, but mine is semi-new so idk. Any help, will be great. Thanks
Cody240
Car: 1990 240sx SE white with KA24DE
I cant help you on the squeal since you pretty much said you did every thing i can think to do, but dude your sig is seriously werd
1996N1ss@n240SX
Car: 1996 Nissan 240SX, 2001 Honda Accord Fully Stacked
try to have some belt cleaner...well all i know is my car did that...and then BOOM...engine just blew...but thats cuz i needed a valve job...just grease everything up nice....not too much or belts will slip...its ur accessory belts
Frank E Bones
Car: Slower than it looks
Have u replaced the Throw-Out Bearing? My car was doing the same thing, then it went away after I replaced it. Just make sure they/you lubricate the right parts when you replace it.This might help - http://www.nicoclub.com/articles.php?id=316656
nevertheless
Car: 1993 240sx hatch
1995 Nissan D21
Mine does it too, I have an oil leak coming from my valve cover because of a stripped bolt. Might wanna check that.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Or try some new quality belts adjusted right
Two Fowty
well over lunch, i tried running water over the belts and whenever i poured it on the lower one, not sure what it goes to, the squealing stopped. so i guess that means i replace that one? the belt only has like 3k miles on it though, so hm..
and just on a question about the TOB, are they like.. universal. I have an upgraded clutch (clutchmasters stage 5) so would I have to go to them to get a TOB or could I just hit up autozone and get an OEM one.
HurryupandrunS13
Car: 1992 240 fastback
OutToWinPAHC wrote:Or try some new quality belts adjusted right
You can tell who turns wrenches in here.....
All pulleys spin freely without a belt on them? All pulleys aligned properly, and accessory mounting bolts tight?
Two Fowty
pretty sure its the alternator belt, so i ordered a new one. cause while squealing, i poured water on it and no squeal.
locoluna825
Car: 90 240sx coupe
usually when belts get wet they slip and squel lol wierd
HurryupandrunS13
Spin all of your pulleys without the belts on them, except for the crank...of course. Id just hate to see you keep throwin money on belts if one of your pulleys is locking up. Best of luck getting rid of the nails across the chalkboard....
manticore33
Car: 1993 Nissan 240sx
I had some belt squeal on 5k RPMS + and it turned out to be a failing fan clutch causing pulley resistance since the fan was not "slipping" properly.
