I've recently swapped an '89 Pathfinder rear end with LSD and 4.6 gears into my '02 Frontier Ka24de 5speed...
...annnnd now with the shorter gearing, 80mph actual speed reads as 100mph on the speedo and triggers the speed governor!
I've contacted a few ECU tuners/programmers (JetPerfomance, JimWolfTech, ect...) and no one seems to have an answer for removing the governor function except for swapping for another ECU from perhaps a 240sx.
I know that some of the 240 guys look for the automatic ECU's because they don't have a governor (speed is limited by the auto trans ecu)
My question(s) are:
-is there a way to override the factory speed governor (short of removing the speedo cable)?
or
-will an S14 auto trans ECU mate up to my Frontier harness/system? (and would I have to then run the S14 intake assembly/maf?)
I've done quite a bit of searching on this topic, and the majority of the replies regarding the speed governor removal are from members chiding the author, repremanding him/her for 'driving reckessly' and endangering others.
I daily drive my truck, but I also track it weekly, which is the only reason I need to overcome this limitation.
I'm not looking for personal opinions on public safety. I'm older than most members here, and don't drive recklessly on the street. enough said.
thanks guys
