Desert Rat »
https://forums.nicoclub.com/desert-rat-u54558.html
Mon Nov 01, 2010 7:05 am
The R50 pathfinders use quite a few different parts....Tcase and front axle are both different. The front axle in an R50 is a high pinion version of the R200, and the cases in the Infinity versions have different gearing...not sure about mounting points. Internals are the same on the Pathfinder cases though, so one of those might work.
Best thing to do is source a wrecked vehicle for your parts, especially since you're wanting to convert to a manual - there's a lot of little parts that need to be swapped that acquiring individually, they could get expensive.
You need:
4x4 spindles
4x4 halfshafts, front axle. Front axle will need to come from 99-04 Frontier or 2000-01 Xterra with HG46 axle code
4x4 steering and axle crossmembers
Front and rear driveshaft
Transmission / Transfer case
Clutch master cyilinder
Clutch pedal assembly
I believe there's some wiring harness changes to convert as well, and your automatic ECU *might* work.
Interior console from a manual transmission truck with shift boots, etc - from 99-01 Frontier or 2000-01 Xterra
Yes, it's been done, but in the long run you'll find it cheaper and easier to sell the truck you have and go shopping for the truck you want. The 2wd chassis you have and the 4x4 chassis are identical, so there is no fabbing required - it's all bolt in. It's just a matter of how cheaply you can find all your parts.
