Desert Rat »
https://forums.nicoclub.com/desert-rat-u54558.html
Tue Nov 24, 2009 12:01 pm
All D21/D22 Hardbody/Pathfinder/Xterra/Frontier wheels should interchange from 1986.5-2004. The 96-04 R50 Pathfinder rims will also bolt up, and I think 720 4x4 rims will as well.
Add also to the list 6 lug Toyota 4x4 wheels, Isuzu, Mitsu, etc.
It's a very common 6 on 5.5" lug pattern. The Nissans I mentioned used 14, 14, 16, and 17 inch wheels, but all will bolt up. Obviously tire size has to be suited to the vehicle, but in general, a 31x10.50 is the largest tire that fits without lifting on the 4x4s and 235/75/15 (about 28.5") is the biggest for the small 2wds, generally speaking. Larger rim sizes can be used with lower aspect ratio tire sizes. 14" 2wd rims will not clear the brakes on a 4x4.
