D21 Tacho,
ramerry
Car: 1996 D21 Dual Cab, Z30e engine, bull bar, sun roof, air con all factory fitted
Hi, I am new to the forum & live in Australia. I have a 6/1996 Japanese built Nissan D21, Dual Cab, Z30e V6, Bull Bar, Sun Roof, Air Con, power windows all Nissan Factory fitted. Two tone paint, really dark green over a light gold.
My problem is the Tacho, it works when it want to. It works fine then starts jumping up & down & also does nothing if you tap the Instrument panel it might start to work, I have a friend who has a Pathfinder that does the same.
Does anybody have any ideas of the cause & can it be fixed.
regards to all.
Richard
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Happens a lot to the D21 trucks over here too. It's electrical and the best bet is to open up the gauge cluster and replace the tachometer.
ramerry
Hi, thanks for reply, had a feeling that might be the case , I was hoping it might have been a dry solder joint or something similar.
Regards
Richard
