Desert Rat »
https://forums.nicoclub.com/desert-rat-u54558.html
Thu Dec 06, 2007 5:42 am
Yeah, check out your brakes.
I would start by bleeding the system to see if that helps. You probably have 12 year old brake fluid in there. How many miles do you have?
It's also likely you have a caliper sticking, particularly if those are also as old as the truck. Check them out for rusty pins, etc. You might get lucky and just need to clean them up. Pull them off and pull out the pads to look for fluid leaks around the pistons.
