d21 pickup rear sway bar
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
hey guys
i am looking at rear sway bars for the d21 hardbody. I know at some point Nissan offered a 7/8" sway bar for our trucks, but i am not finding it anywhere. Has anyone added one to their truck? yay or nay?
I only found this on ebay... ( http://cgi.ebay.com/ebaymotors...ories ) has anyone tried this? Specs seem same as stock...
cheers for any input!Marko
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Hellwig makes RSBs for our trucks. So does Stillen.
BronkStang
Car: 06 commander,94 HB Freddie,97 HB autox, 89 Bronco-stang
i run a 7/8 solid addco rear sway bar it was about 180 from summit racing for a 2wd truck. the 4wd bar was cheaper, about 120. they also offer a 3/4 bar, a belltech and a hellwig. like he said stillen has a bar too.
if you have stock rear springs you'll like the difference, roll is dramatically decreased, especially when hauling something. you know that feeling like the truck is getting steered from the rear and the front end is light? it really adds some stability.
now i asked if you have stock rear springs because i have stiffer rear springs. they decreased roll and allowed me to carry more weight, even though they lowered the truck 3 inches! the sway bar merely added extra stiffness and oversteer through the turns
the only thing i've noticed that is different between sway bar mfg's is the mounting style. o know there was one in particular which caused clearance problems with larger rear tires.http://www.cardomain.com/ride/257388scroll down theres a pic of the swaybar right next to the rear tire NOT COOL. mine mounts behind the rear axle, no clearance issues. so does hellwig. i am not sure about belltech and stillen
the nismo 2008 catalog doesn't list a rear bar for our trucks, only a front bar. maybe they offered it in the past?
Modified by BronkStang at 2:46 PM 1/13/2010
seang
Car: Ford Fiesta ST
BronkStang AutoX videos! Your truck is sick!
