GareBear »
https://forums.nicoclub.com/garebear-u308221.html
Mon May 22, 2023 5:17 am
I recently picked up a slightly mashed in '97 King Cab. I found a '93 Pathfinder for the entire front wrap. There is a difference in the height of the core support mounts that are welded to the frame. I can only assume this is due to a taller radiator for the V6 compared to the KA24. Sadly, I pitched the original radiator before I could set them side by side to confirm this. I'm new to the Hardbody/Pathfinder models, but I thought I'd mention what I've encountered so far if I can help someone else. My solution has been to swap these weld-on core support mounts from the Pathfinder as well. However, to get the front wrap to sit somewhat correctly against the cab and maintain fender to door gaps, etc., I had to raise them a little higher on the D21 frame than they were on the Pathfinder. I'm no body man by any means, but for whatever reason, this is what was required in my situation. Bumper mounts were slightly different as well. None of this may apply in your case, but it is worth mentioning just because I did not expect to run into this variation.
Good luck!
