I am building a d21 to race in the Lucas Oil Regional Series in So Cal and also will race select races in AZ.
I am looking to get everything i can out of this thing. 5:89 gears from nismo, it has a ka24e, with the 240sx intake manifold and air filter, doug thorley headers, method wheels, falken tires, icon shocks, seats, cell etc etc...
what i need help with is...
i need a wiring schematic to re-wire the ignition system. i would like to make it a push to start button, which is easy to give power to the switch, then feed it into the starting cylinoid(sp) to crank it over. EASY
i need a wiring schematic to re-wire the iginition system, so that when i flip a switch, it is like turning on the key to the full on position, just shy of cranking the engine over. what i need is to figure out what wire is the main power wire for the ignition.
i got a 90' stanza computer, and clipped all of the harnesses under the driverside steering column, i was told through NISMO that the stanza had a bitchin diag port that can be read through a blast computer as a data logger.
i have a wiring harness off of a 240sx, 89', from the motor, through the firewall to the computer.
i need to get this thing running again, getting it fuel from the new fuel pump is easy, getting the battery to power the starter, and wiring the starter to crank is easy, but getting the computer to "turn on" all of the sensors is going to be a pain. any help is much appreciated.
i will be going through Jim Wolfe Technologies for the computer tune, and nissan motorsports is helping me with torsions, gears, etc.
any help i can get from here will take me a long way. i want this thing to be running like asap, i need the schematic right off the bat. here are pics to show im serious. i have a lot of people backing this thing and would love to show people the nissan is the one to beat!
Sean Kepler
[email protected]
