Desert Rat »
https://forums.nicoclub.com/desert-rat-u54558.html
Wed Aug 01, 2007 5:29 am
The TX-10A is a married unit and has to have a 4wd transmission to mate to. 2wd trannies simply have a tail housing to insert a driveshaft into, so you'll have to figure something else out for the transfer case (or engineer a blocking plate that can convert the Nissan case to a divorced unit. You'd also likely have to move it back in the frame a bit.
A divorced unit, like Bigbird said, is the best bet. There weren't many divorced driver side output tcases made to my knowledge, but you can go with an aftermarket case such as an atlas. New driveshafts will be needed, as well as a short shaft to go from the transmission into the case.
This would be a really cool swap. All the wiring will have to come from the donor car, as will the ECU, etc. Making all your gauges, etc. work, and the AC, etc. will be the hardest part of the swap. You'll also need to upgrade the cooling system, as the HB radiator won't cut it for the V8.
