Hey all, thanks for reading. I was driving my 97 d21 the past few days and it seemed like a growing vacuum problem. When releasing clutch from stop or low engine speed (under 2k rpm) I have to goose gas to raise rpms. If i ease onto the gas engine bogs down and stalls. Same thing happens when shifting to second or third between (1800-2100rpm). No change due to temp or time running. (Idled fine)
Today the problem escalated. Unable to start after running fine. Id disconnected terminals to reset computer today. found one of clips coming from battery + contained a disconnected wire in harness which i reattached to the clip.
Im going try and replace these wires coming from battery + and refit into clips. Anyone know of related connections issues that may cause running/ starting problems
