D2/k-sport coilover owners... loud knocking sound in cold?
publicenemy137
Car: cars, cars, and cars
Got D2s installed late summer. Now that's it's colder, my coilovers are making really loud knocking sounds. The colder it is, the louder the sounds are. It'll makea slight noise at 55-60 degrees (probably from when it's still cold in the morn), and when it's 35 it makes constantly *KOK KOK* sounds from all coilovers. Anyone else have this problem? Is this because it is oil-based?
publicenemy137
no one else has this ****ty problem except me?
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
I got K2's, they just sqeek. Go back over and tighten everything up, usually fixes alot of problems
publicenemy137
so take out my rims, and just tight the bolts up more? And yours didn't sqeak anymore? And yea mine more like sqeek, loudly
crzycav86
Car: 93 Nissan 240SX KAT
Well.. squeaking is normal.
Operating temperature is -5 to 60 degrees Celsius, so it's probably not knocking because of the cold weather. The gas heats up anyway after you drive it for some time. Does the knocking go away after you drive for awhile?
It's probably just some loose nuts..
publicenemy137
it doesn't really go away after 30 minutes of driving, it does tend to get slightly quieter though but not by much. I'll try tightening up the nuts then. Squeaking is normal though? But is it supposed to be loud?
krazy skwerel
Car: 1989 240SX Coupe down for the count
2005 Honda Accord
1974 Ford Mustang II
Man I have the exact same problem. is it when your turning your steering wheel? We found it to be the spring turning. I have been meaning to tighten the spring tension a bit to see if it fixes it. If anybody else has other ideas please let me know.
publicenemy137
no, it makes that loud squeaking noise whenever I drive over a small bump or uneven part of the road. It can be smooth but the slightly uneven part of the road will make it squeak..
