Project S13 »
https://forums.nicoclub.com/project-s13-u21998.html
Mon Jun 20, 2005 3:28 pm
Glad I could help
My problem was coming from the tie tod, and I'm replacing it so I have no doubt that will fix *my* problem. My best advice is to jack up the front end and look/shake around to try and see what's loose or has any play and start from there. Also look for ruptured or leaking bushings and replace those when you have the time. If nothing else you are replacing things that will improve your car's handling anyway.
I purchased tein tie rods, rod ends, and thier tension rod kit and it should get in this week. Looking forward to it but yeah it will surely fix my problem, dunno what exactly is wrong with yours though so getting what I got may be a bad idea unless you were going to spend money on those specifc upgrades anyway. You will probably have to mess around down there until you discover the problem yourself. Good luck.
