Hi folks, I bought a DEI-brand alarm/keyless entry/remote start, and am just gathering some specific's while it's being shipped. First, I *assumed* the driver-side door in my '92 240 did not have an actuator. However there's one shown in my FSM. Is this different between trim models? If I unlock my passenger door, the D/S does not unlock. Of course it may not be working properly.
If I do, is it better to use the control signal to the timer unit, or bypass the timer(and use the alarm unit's pulsed output). I guess if I bypassed the timer I would probably need relays. Apparently this is a single-wire lock/ul system: pulse to ground to lock, and open to unlock.
In the case that I don't, I bought an actuator anyways(only $7-I'll use it on the trunk if I dont need it). Will this actuator properly unlock the P/S door? Also there were no details about the actuator in regards to current draw: 'think I can use the 'active speaker' power wire to supply power to the actuator?(amps were removed).
Thanks! I'll try to make a write-up as I install it.
-Jamie
