D-I-Y Front Lip for 1st Gen. Rogue
casperfun
Car: 2009 Nissan Rogue SL AWD - Indigo Blue
:mike Bought some garage trim
Attach in your own personal way.
I used outdoor 10 pound weight limit double sided tape but NOT 3M auto version because way cheaper. And some clips from an old hanger. Very crude set up. It was difficult sticking to the plasti-dip panel but holding for now.
Only did corners since I have a Bullbar; but you get the idea.
Just a hint of a change, you don't really notice unless you really look for it.
Can be removed easily. No biggie. :dance
:domo:
trokita
Car: 2017.5 Rogue SL AWD Magnetic Black (Sold Sep2022)
2022 Lexus RX450H F-SPORT Cavier Black
2008 Rogue SL AWD Wicked Black
2005 Subaru WRX Limited Black
I went with the EZ-Lip Pro. Don't know how long it will last but gives it a look. comes with 3M tape already attached...but still had to use a couple of washers and self tapping screws on the corners.
casperfun
I almost went that route, but i had a cheap impulse moment for less than $15. Your stuff probably looks way better up close. But during the quick everyday glimpse by the public, the generic universal and garage trim all look the same.
Did you do the rear bumper, i bet it looks great! :chuckle:
trokita
Thanks- I looked at both options , but went the EZ Lip Pro only because of the 3m tape and the width. Well the stuff didn't have much "stick" even after following the directions. Used heat gun and so on. This stuff is pretty pricy for what it actually is----foam. Found an amazon deal but still paid 40 bux. Was thinking of looking for a poly urethane lip...maybe from an impreza? Gonna try the one from my 05 on it?
darylzero
trokita wrote:I went with the EZ-Lip Pro. Don't know how long it will last but gives it a look. comes with 3M tape already attached...but still had to use a couple of washers and self tapping screws on the corners.
I like that, it's a nice understated look.
Return to “Rogue Forum”
