bobr1948 »
https://forums.nicoclub.com/bobr1948-u194955.html
Sun Dec 11, 2011 3:42 am
I had an ex tank mechanic who has his own one man transmission shop rebuild it.
After he removed the guts he called me and said he could not figure out why the transmission was "hanging". I brought the shifter lever with me. I looked at the tailshaft bushing which was very worn, but all the bearings and synchro were all good. What was missing and I found it in the bottom of the case, was a white plastic bushing that fits on the end of the shift lever and goes into the internal shifter linkage. It had worn and dropped out. At least it had not gotten ground up in the transmission. We decided not to rebuilt the whole transmission (just a partial rebuild, bushings and bearings) as there were not stripped gears or bad synchros. I have learned that you have to be very very careful when you go to stab the shifter linkage into the transmission so as NOT to dislodge that white bushing. Now the transmission shift perfect, just like a new one. All told cost me $225.00 which was a deal compared to others.
At first I went to Autozone and they sell a rebuild kit which includes the synchros, bearings and bushings for $150.00. But I have had so much trouble with their crummy rebuild parts that I would by elsewhere whenever possible. I don't know where my guy gets his parts but I could ask him, if you let me know.
One thing is Penzoil has a bulletin out that G4 is NOT interchangeable for G5. Also should NOT use regular oil as it will break down any brass parts in the transmission which include the tailshaft bushing.
