a.p.barron »
https://forums.nicoclub.com/a-p-barron-u157818.html
Thu Jan 24, 2013 12:05 pm
My CZP brace didn't quite fit, so the first time I tried to install it, I cross threaded the bolts, ended up stripping the threads in the Z and broke off the bolt heads because I over-torqued them (doesn't take much). :-\ I re-tapped the bolt holes and almost did it again! After looking at the brace, I noticed that the holes on the brace weren't far apart enough for me to install it smoothly, so I had re-drill the holes to make it fit. What should have taken 10 mins took me a lot more than that. :-( Anyway, after installing it, I noticed a huge difference. I installed SS lines, slotted rotors, and new pads not too long ago, and I think the BMC brace made more of a difference than the new brakes components!
