Well.. i unplugged the o2 sensors and it didn't change to much. I'm still going to replace the o2 sensors because when i did the diagnostic with the ecu they didn't respond like they should've. I wonder if my headers could make the engine run rich. I opened the idle valve quite a bit, adjusted the timing some. After all that the smoking stopped but still has rich smell in the exhaust. No fuel on the plugs. I replaced the PTU and it starts better now. I'm still running bosch platinum plugs and i'm sure when i change those to NGK the richness should diminish. If the plugs don't solve the problem i will be out of options. I got to figure this out because when i tag this car i will have to get the emissions done soon after.Blurr wrote:Bent sounds like the same problem I have. Let me know what your remedy is cause I think Ill follow suit on repairs...
I'm thinking that might be it because when i bought the car the last owner had hacked the o2 sensor to connect to a air/fuel gauge. I connected the ends back together but i guess its still having issues.Oh Em Zee wrote:#1,3,5 rich = one side of engine = one side of headers = 1 o2 sensor.
evildky wrote:cat might be dead on that side
Thank you for your response. Looks like I will be checking my o2 sensors and exhaust installation before I put in my new plugs and just fry those as well.Oh Em Zee wrote:i'm unsure for your situation E_Cruz1989, it seems odd that you would get lean on one side, rich on the other, because O2 sensors dont go bad that often it seems (for there to be two bad O2 sensors. just think of all the things that effect fuel delivery, and why the ecu would send either too much fuel to 1-3-5 to compensate for 2-4-6. the best advice i can safely give because of my inexperience, is to check the wiring on your o2 sensors, make sure your exhaust is bolted up properly from the headers back if you have the access, because it's not too hard to do and it's free, vs paying a few hundred for fuel injectors before knowing that's your problem.
it's really unlikely you are having problems with your fuel injectors being that it's practically all cylinders. if one goes bad however, the others on that side of the engine quickly follow.
Thanks. I'll get a temp gauge and see what's up.evildky wrote:a working cat should be very very hot, if the issue is only on 1 bank then compare the temps of the 2 cats, if the non rich side is hotter than the rich side then you found the problem if they are about the same or the rich side is hotter you continue troubleshooting
I changed my plugs to the required oem ngk PFR6B-11, 6G-11, 5B-11plugs and it reduced the rich smell a bit. Then i adjusted the idle to 850 rpm but i'm still trying to get it to go 750rpm. That reduced the smoking from the tail. A friend gave me some valvoline fuel system cleaner and i put that in on a low tank. I let it run for a while until it was almost empty and then put in about 1/4 tank of 89 octane gas. I then took the car for a drive until the tank was almost empty again. Then i put in another 1/4 tank of 93 octane gas and drove out on the highway for about 15-30 min. When i returned to my garage the rich smell was gone and the exhaust smelled like it should. I guess an injector may have been dirty or the converter may have gotten cleaned by the fuel treatment. Thats what i did but i'm not sure it this will fix your issue but you can try.Blurr wrote:Bent sounds like the same problem I have. Let me know what your remedy is cause I think Ill follow suit on repairs...
I knew it was something else and not a temp gauge. Thanks for making that clear.evildky wrote:not a temp gauge, a lazer or infared thermometer
Before i changed my plugs my z idled like crap. I found that 4 of my coilpacks were split open. My friend found out the hard way which ones were bad. They were split at the top just under where the mounting holes are.E_Cruz1989 wrote:Don't mean to thread jack OP, but my thread barely gets read anymore lol, I replaced my spark plugs and o2 sensors, and I'm still feeling misfire, where should I check next? The misfire is only during idle, under normal driving conditions the car drives as it should and has the power.
