Cylinder Wear Diagnosis for KA24DE
Chezedik
Car: 1991 Nissan 240sx
I know it probably does not matter what motor we are dealing with, but I thought that it might help you guys out. Here were my compression #s:
130, 135, 132, 150
Oil makes them all higher, something like:
150, 155, 160, 180
Now, I am no fool, and I know this indicates worn rings. What I want to know is, can I tell how the cylinder is worn without removing the head? When I put the engine together, I checked the Ring End Gap, and they were all at near the end of their tolerance. So, I was thinking about some Total Seal rings, which should resolve this problem, without overboring, right? Obviously, there is no chance if they are egg-shaped, which is what I want to know (I did not have a bore indicator, or I would have checked).
Oh, and one reason the compression is so low is because I have a Cometic .120" Head Gasket. My compression should be 8.6:1 according to the formula, so I should be looking at about 150-160psi, but I am not.
Please help, if I cannot figure this out, I will have to get an SR. And maybe still, if I have a problem.
rotorimp
Car: 02 Xterra, 60 IH Metro
It will vary between hot and cold.
It may not indicate worn rings--may be just the rings are not broken in yet. If the rings are the problem then your oil will get dirty quick-How many miles are on the motor now? I always break in a motor for at least a 1000 miles before I start looking for compression numbers (also depends on the hone)
Chezedik
When I put it back together, it was because I spun a rod/ threw a rod due to lack of oil. The rings have 110mi on them, and I did NOT change them but I did check the end gap. In the previous build, I was not using this head gasket, and the compression were about 180psi +/- 5 psi (cold, and un-ran) across the board.
So why now, do I have uneven compression? That would indicate cylinder wear due to lack of oil (it seized, until I added oil and let it cool).
The rings looked good, but now this. It doesn't seem to be a head gasket, and I just reshimmed the valves in order to verify clearance.
Right now, the engine will not start because there is too much fuel (I think), so I will be playing with the tune to lean it out.
So it seems to me that I have at least slightly worn cyls. The question is, does anyone know of a good way to tell what sort of wear is happening in the cylinder? I would think that there is not a good way of knowing without taking the head off (which isn't a big deal), but I want to have any parts ready before I do. Also, if they are egged and need to be bored, then I might as well just sell the motor.
theother1wstolen
Car: 92 240sx Coupe SE
I'm not 100% on this but i believe i read somewhere that if you have too much fuel in the cylinder it will decrease your compression. someone chime in and correct me if im wrong.
Chezedik
It has, but when I clear the chamber by pulling the plugs and letting it sit overnight, that is when I get my numbers that I mentioned. Can piston rings ever fill an egged out cylinder? If my cylinders are just a little worn, then I will go Total Seal.
Again, does anyone know if there is a way to tell if a cylinder is egged without pulling the head?
180fan
Car: 89 fastback
Nope...
Chezedik
That is what I thought, which is why I may be going SR soon...
LayNLow240
Car: 92 240 coupe
well you DID say you let it sit overnight, it needs to be done when the engine is warmed up. that could change the numbers a little bit.
Chezedik
I agree, I am going to install my chip and see what it does, then test it warm. If the numbers are still ****ed, then I may change the rings. Also, there are guys who bore out motors for boats (needs to be done on a mobile basis, because removing the engine can require removal of the deck), so maybe I can tow my car to a marina.
