MrFox »
https://forums.nicoclub.com/mrfox-u558.html
Sat Sep 13, 2003 10:14 am
A few thoughts:
The chief type of friction experience by the piston assembly should not be rubbing friction, but viscious friction from hydrodynamic lubrication, where the assembly rides on a film of oil on the cylinder walls.
However, the strength of the oil film in hydrodynamic lubrication is dependent on both piston velocity and normal pressure. A good visualisation is a hydroplaning tire: When sliding velocity becomes low, or when footprint pressure is high, hydroplaning stops. If hydrodynamic friction breaks down, rubbing friction results. Imagine the difference in magnitude between the 2 types of friction.
The bad thing is that rubbing friction will occur - the piston slows down and stops quite a bit in a reciprocating engine.
In addition to the loads on the piston skirt already discussed previously, compression rings are designed to seal harder with increasing combustion chamber pressure - thus ring contact pressure is a function of cylinder pressure in addition to ring tension.
My thoughts are that the ratio of contact pressure to piston velocity (as functions of bore and stroke) can be optimized in order to minimize the overall amount of friction for various engine loadings and speeds.
Does this sound reasonable?
