Titan1x77 »
https://forums.nicoclub.com/titan1x77-u135718.html
Sun Jun 07, 2009 4:22 pm
Hello, I have a 93 Nissan Sentra which is not firing in cylinder #4...
1. checked spark plug wires, simple check by holding to the valve cover which results in spark.
Swapped plugs from cylinder 3 into 4 and same result, haven't swapped wires since #4 wire wont
reach the 3rd cylinder.
2. Listened to injectors with a long flat head screw driver, the problem cylinder has a
slightly louder click to it, but doesnt seem abnormal, also removed plug and had a slight gas
scent to it.
3. Compression... Havent got to test this yet, but i did remove plug (to see once connected to
wire for spark) and it was gasping and blowing air... Friend is on his way over this week with
a gauge, I'll get back to you on the reading for all cylinders.
A little background on the car...
Ive had some faulty wiring problems, speedometer/odometer hasn't worked in 4-5 years after
replacing a starter and my left blinker was wacky and would stay stuck on only when my
headlight were on,when headlights were off my right and left would blink,that fixed itself
somehow. if compression is ok, which sensors should i start to check? or what would you suggest I check?
