I already posted this in the wrong forum and tried to delete it to no avail, but I wanted to post here because it's more appropriate and I hope to get more suggestions...
Last year I had a problem with my 240 running rough, so I pulled out the distributor by accident (please don't ask) while replacing the distributor cap and rotor. After much screwing around, I finally got the timing right again, and all was fine. Fast forward to this year. I took the car out of storage, ran back and forth to work a few times in it, and the #1 cylinder started not firing. I pulled the plug, cleaned it up, and once back in the car ran fine. After a round trip to work (40 miles), it's doing it again, and the plug looks fine. So...
1) I popped the hood and pulled the wire on #1, and no difference, same on #2 and almost stalled out. So, #1 isn't firing.
2) I switched the #1 and #2 wires and #1 still didn't fire.
3) I switched the #1 and #2 plugs and #1 still didn't fire.
4) The distributor cap and rotor are basically new.
I'm figuring either there is no spark now to #1 (doubtful), I have a blocked fuel injector, or I have some other problem. I'm hoping you guys can give me a hand diagnosing/fixing this before I have to take it in to a shop.
Thanks.
