invain »
https://forums.nicoclub.com/invain-u96301.html
Sun Apr 05, 2009 11:43 am
This fall my 98' 240sx started running on 3 cylinders randomly. Somedays the car would be fine, other days it'd run like s***. For a while I thought the ecu just needed to be retuned, but one day while the car started running like s*** I pulled off to the side of the road and started pulling plug wires. Come to find out, cylinder 2 was dead. At the time the problem was very spontaneous, and it seemed like everytime I wanted to work on it things would be running normally again.
A couple months later and the randomness stopped and the car has been running on 3 cylinders ever since. I drove home a couple times and spent hours checking things over trying to diagnose the problem. Plugs/wires/distributor are all farily new, spark tested fine for that cylinder numerous times. Compression test was fine. Injectors are all farily new but we swapped injectors from clinder 2 to cylinder 1 and tested impedence of all injectors - all 4 are working fine. We checked the voltage at the injector plug for cylinder 2 and it was pretty low. We tore into the wiring harness and found some pretty s***ty wires. Put in lots of new wire, voltage is now good at all 4 injectors, however the cylinder was still not firing. Since voltage was good we then checked the ground signal from the ECU, and found that the signal for injector 2 was not pulsing. We tested the impedence of the ground wire to the injector plug for cylinder 2 from the ECU harness and found no problems. Since the wiring appears fine, the only other option left was the ECU its self. I had a second stock ECU that came with the car, so we swapped that in. Cylinder 2 was still not firing.
This is pretty much as far as I've gotten. I'm at school so the car has been sitting most of the winter. Now that it's spring and I'm almost done with class I need to start working on this again as I need the car for my summer job. At this point however, I'm completely stumped. Everything we've tested/checked as turned out normal. I was sure it'd turn out to be injector drivers in the ECU or something until we swapped in another ECU. I've even been in contact with the guy that tuned the first ECU and after describing everything I'd done he doesn't believe the ECU is the problem either.
What the hell else is there to check? I know there's voltage at the injector plug, it's just not getting a ground signal. I've checked the ground wire multiple times, but maybe there's some really small short I'm not detecting? I've thought about just running a new ground wire from the plug to the harness. If that doesn't work however, what would you guys do next? I'm completely stumped.
