Sounds like he put synthetic oil in a high mileage engine that was used to conventional (dino) oil. This will cause old seals to leak, so that's probably what happened. Post up the results of the compression test when you get around to doing it, it will tell how healthy the internals are.Droldaerd wrote:Not sure. The guy gave me this story that he put royal purple into it and that it wasn't meant for early NA 300s and that it screwed his engine and his dad had to rebuild it in order to clean it out. Not sure what much of its true or if that was the reason, but there's visible silicons in some regions of the engine, valve cover leak, oil pan leak, and possible leak from behind timing chain.
Question, are all the clips on the coil pack connectors broken? I'm betting they are (90% of peoples are) and don't hold tight any more. Z1 sells a set of brand new connectors for $30, you just have to de-pin the old ones and push them into the new ones. It's a fairly simple process.Droldaerd wrote:Thanks for the info everyone!
Update: I haven't run the test yet, but after double checking to make sure I know which cylinder gives me the problem. I also noticed that moving the any part of the harness near the coil packs or the connectors that are near the ptu (not the ones attached to it, just the ones that have a connector near it), will cause the engine to nearly die out. Am I due for a new harness? Giving the pricing on them, even used (with risk), I'm starting to wonder If i should ditch this Z and start with a different one.
I will do that, thanks for the infoThisIsSparTTa wrote:You have a 91, which means you originally had the old style PTU. After the recall, the new style used a sub-harness to connect to the existing harness. This subharness creates all kinds of problems. I could kill my engine by moving it, as you described. Best solution is to cut the wires 1 by 1 and directly solder them together. You don't actually need the subharness for anything, and can still disconnect from the PTU without it.
On that note, here's the how-to:ThisIsSparTTa wrote:You have a 91, which means you originally had the old style PTU. After the recall, the new style used a sub-harness to connect to the existing harness. This subharness creates all kinds of problems. I could kill my engine by moving it, as you described. Best solution is to cut the wires 1 by 1 and directly solder them together. You don't actually need the subharness for anything, and can still disconnect from the PTU without it.
