CYLINDER HEADS
AAPman23
Car: 1992 Maxima SE VE30DE
Found some headers on ebay for a SOHC. Will they work on my DOHC? Or are the bolt patterns different?
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
I would try to find out if stock manifolds are the same part numbers or not. Check at your local Advance Auto Parts or local dealership. If stock part numbers are same for SOHC and DOHC, go for it.
blackmax23
Car: 1999 Nissan Maxima SE-L
In your Topic title, you have cylinder heads, but then you discuss ebay headers, which ones are you asking about, heads or headers?
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Heads or headers, it won't work. Headers (exhaust manifolds) don't work because ports are different and bolt patterns are different. Cylinder heads don't work because they're different engines...different bolt patterns, completely different valvetrain setups.
Chris92SE
Car: 2017 Infiniti QX30
2003 Nissan Pathfinder LE
No one makes headers for the VE engine.
However, the stock exhaust manifolds are designed pretty well. If you add a better flowing aftermarket Y-pipe, you will be just as well off as someone with headers. The install is pretty easy on the Y-pipe, too.
warpspeed is the most common type and it cost about $200 with all of the gaskets and stuff.
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
I second what Chris said. The Maxima's already come with tubular exhaust manifolds and are pretty decent. The main problem is the y-pipe and an aftermarket piece will get you a decent gain in power.
