t.mcginley.jr wrote:A handful of people have reused old head bolts without issue supposedly. The problem is that when the bolt is torqued to 90 ft-lbs it stretches. So when you try and use them again and torque them down the torque won't be accurate. Again, a few people have reused them, some of which added 5 or 10 ft-lbs to make up for the stretching but that's just guesswork. If you torque the used head bolts to 90 ft-lbs, it's possible that they won't seal the head correctly because it really isn't at 90 lbs.
Please explain... cause as you know I'm doing a build and haven't purchased new ones. The FSM calls for torquing them down, then pulling them back and re-torquing again. I'm confused as to how that is different than reusing them.. Just curious
