OutToWinPAHC wrote:could be more then worn rings... now I have to ask. You sure the compression tester was tight enough in the hole? Because those number are LOW, like really really really low.
to be honest maybe not, i should try again. The first time i did the compression test awhile back I got the tester stuck in my spark plug hole, it would spin but not unscrew, left it overnight and the next morning it unscrewed easily, so im a little gun shy about putting them in too tight.
But even when i put it in that tight cylinder 1 still was testing around 60 and the rest were in the 120+ range.
The only thing that I cant figure out is the car drove fine, didnt overheat or anything, got home and parked it for about a week. (only really drove it around on weekends) Tried to start it up and it didnt sound right, figured out cylinder 1 wasnt firing.
Replaced the fuel injector, tested the plug, tested for spark..everything is there and that's when i checked the compression. Then being an idiot I let someone convince me it could be a valve/head gasket issue, so i took the head off and had the valves checked, they were fine. Then i replaced the headgasket and have the same problem, so now im going to tear it apart again and replace the pistons/rings.
