streetspirit7 »
https://forums.nicoclub.com/streetspirit7-u14716.html
Sun May 02, 2010 7:57 pm
Ok, for some reason my cylinder 4 is not firing. When I pull the plug wire or injector harness there is no change in my rough idle, so I should be a problem there. I'm still getting spark to that cylinder, so it must be fuel right? I've done the tests in the FSM, the injector harness has power and there is continuity between the harness and the ecu plug. The injector continuity has within spec, and I've tried replacing the injector. Could my problem be the ecu, or somwhere else. If it is the ECU, is there a way to check that without replacing it?
