Annie4 »
https://forums.nicoclub.com/annie4-u164082.html
Sat Jul 10, 2010 5:48 am
Last night about a half hour after I had last used my Pathfinder I went to start it and it wouldn't start. I ended up leaving it for a few hours to go out for dinner and tried it again when I came back. It started up fine but the check engine light came on.
This morning I hooked up my code reader which gave me the code P0304 -Camshaft Position Sensor A Circuit (Bank 1 or single sensor)
When I looked this code up on here it says that P0304 is a Cylinder 4 misfire detected.
Edited to add that there was another stored code. It's P0158 which is high voltage to the O2 sensor, Bank 2 sensor 2.
Can someone explain to me what happens next? Is this a spark plug issue or a bad gas issue or are there other possibilities? Any thoughts would be greatly appreciated
Thanks for your help!
Annie4 on Sat Jul 10, 2010 7:00 am, edited 1 time in total.
