cylinder 3 not firing
mias13
Car: 1991 Nissan 240sx
last night i go and pick up my car from my friends house and cylinder 3 just goes dead. i check the spark and theres no spark, i oull out the injector clip and voila the injector is not firing. please help. what could it be. bad injector? possible blown KA?
wa-chiss
Car: 1990 Nissan S13 H/C KA24E
2005 Toyota Sequoia
1976 Honda CB750F Super Sport
kind of sounds like the Hall Effects sensor in the distributor. AKA crankshaft postion sensor. Thats my guess.
510forever
Maybe you have spark but the injector is bad.Use the ohm meter and check if there is any resistance on your injector.If you don't then that's should be it.But when you replace it be very careful not to damage the oring of the injector.
nismoracingsx
Car: 1993 White 240sx Coupe
you're not looking at the whole picture...you're missing spark AND fuel?do what the above poster suggested and check the crankshaft position sensor or perhaps the teeth on the ring for broken teeth.
wa-chiss
2005 Toyota Sequoia
now that I think about it, how can you tell if the injector isn't firing just by pulling the plug? You would need a noid light for that. You can rent them at most parts stores. They just plug into where the injector would go and if there is a signal the light will flash just as if the injector was there.
boyka240
Car: 91 Nissan 240sx Ka24de 270,000 coupe
Every time i use fuel injector cleaner, it kills and injector. It might still work but it can also be clogged at the same time, which will give you the same effect as it not working in an electrical since. also check you wires your plug, distributor cap. u know, something simple like that. you don't always have to dig deep the get treasure
SHIFTVAX
Car: 2006 Nissan Altima SE-R/92 N issan 240 SX
Yeah I think the fuel injector cleanser killed one of mine too that I just got replaced. My KA only has 81000 miles on it.
mias13
SHIFTVAX wrote:Yeah I think the fuel injector cleanser killed one of mine too that I just got replaced. My KA only has 81000 miles on it.
its funny cause i just used some injector cleaner. well i pulled the injector out and it the rail as full of fuel.
MagikDragon
Car: 1991 240SX, 1992 240SX, 1986 MB 190E 2.3-16
One crucial thing I recommend is DO NOT DRIVE THE CAR IF IT IS NOT RUNNING ON ALL CYLINDERS!!
I cannot stress that enough, my brother needs head work now because of a previous owners neglect.
do you have a multimeter? if not buy one they are critical. with the car cold, pull off each injector plug and check for resistance, it should be around 11 ohms at room temp. If the numbers are way off than your injector is fried.
Next check for spark. this should be pretty easy. If both check out, compression is your next test.
There is a kit you can purchase for around $30 at autozone. It comes with instructions and is easy to do. Good luck man keep us posted.
mias13
ok i replaced the injector and all cylinders are firing but now the cars dumping too much fuel
boyka240
maybe check you mass air flow. O2. and intake all around
