WickedRACEr »
https://forums.nicoclub.com/wickedracer-u138196.html
Sat Apr 23, 2011 7:13 pm
Runs like a ka with only 3 cylinders working,... it bucks all over the place responds slower than cold malasses and no power. No engine codes come up on the obd1 reader I used. I know its not working because it runs and I can unplug the injector, spark plug wire, or use the cylinder load test on cylinder #3 and theres no differance in the crappy running and if I do it to any of the other cylinders it dies. I did a compression check because I was almost sure the whole cylinder was smoked but it held compression fine, and using the data reader it told me the injectors were supposed to have between .10-.15 ohms resistance and all did but #3 was way out of bounds so I replaced it and that didnt solve the problem hence the wiring check. and I know the sparks there cuz it arks to a ground and the spark check tool lights up. I don't know if the injector is spraying or getting the ground signal to do so, I don't have a injector noid thing and I didnt feel like pulling the fuel rail and making it spray cuz Im pretty sure it wont. I just dont see any reason left for it not to be gettting the firing signal unless its not getting the ground signal from the ecu, because correct me if I'm wrong the red wire to the injectors is a constant 12 volt and the other gives a blocked ground signal to get to injector to fire? thats my understanding of it any ways. thanks for any help though I'm trying to keep my cool this is getting fairly frustrating cuz I just wana drive my 240 around on all 4 cylinders this summer!
