Rock2025 »
https://forums.nicoclub.com/rock2025-u306726.html
Thu Jul 21, 2022 4:15 pm
Hey all,
2001 QX4 built 06/01 with 148000mi. Early spring I had a misfire on cylinder 2 and after some investigation I found that mice had chewed the wiring to cyl2 injector in half. I repaired the wiring and everything was back to normal and running great. Around this time plugs were changed with Bosch Iridium. Two weeks ago while driving, P0302 and P1320 popped up causing a flashing CEL, poor acceleration and vibration at idle all typical of a dead cylinder. It starts right up no problem but its immediately obvious that I am down a cylinder. Since then
-6 new NGK coil packs
-6 new NGK plugs
-New fuel filter
Cylinder 2 coil pack spark is confirmed, compression test showed 60PSI which I know is low and believe the seals on my tester are leaking. The connector that plugs in to the injector has 14v to ground on one terminal and 3-6v fluctuating on the other to positive. I really don't want to replace injectors but I feel that's what it is coming down to. Cylinder 2 spark plug is dry after running for a few minutes leading me to believe the injector is shot. I just find it odd that it is the same cylinder which I had issues with this spring. I know O2 sensors come into play, but it runs rough as soon as starts regardless of clearing codes or disconnecting the battery. Any last ditch suggestions before the intake gets removed and injectors replaced?
This spring I also had a P1441 PCV Bypass code, P0300 and randomly a EVAP leak would pop up. I believe the EVAP code is from the fuel filler neck leak.
Thanks!
