Nareally »
https://forums.nicoclub.com/nareally-u230129.html
Wed Jul 02, 2014 3:47 pm
(1993 300zx NA 119,235miles) I've read several different forums on dead cylinders for several weeks now but still cant get my problem solved. I've swapped coil pack, and spark plug from a good cylinder, and even replaced all spark plugs with ngk, (even after the fact of swapping cop/plug), I've replaced all injectors, Timing was off a bit so I set it @ 15, Ran PTU test -GOOD-, Got rid of the sub harness, Checked Voltage coming out of PTU on all 6 Wires they all Read the same voltage, above 13vdc, Performed a compression test, Dead cylinder is @ 170,(good) I've cleaned all corroded terminals under the hood, added dielectric grease to all,
(including the CAS) and even the fuses! as well as checked all fuses/relays from inside the car to under the hood, R&R fuel pump controller, Plenum Gasket, Valve cover gaskets, TB gaskets, fuel Rail O rings and Temp sensor,(All parts came from Nissan or z1 motorsports), cleaned the iacv/aac valve, I've tested voltage going to the coil pack as well as the injector, (good voltage on both) Not showing any codes But 55 of course.. I'm in a bog down mode here, Any Help would be great. (All Diagnostics have been done while car was @ normal Op Temp) Other then that it has z1 eprom chip in ecu( I've pulled out the chip just to see if any difference, NONE) H pipe, TT mufflers, JWT POP, and headers. All of the "performance parts" were added @ 80k miles and ran good for a NA, but now its like driving my 88 s10, well maybe not that bad, ha,again thanks for all the Responses!
