cx racing turbo kit.
smitty41393
Car: 1990 240sx fastback (in the process of building)
Hey guys im lookin to turbo m for my ka24de . im looking around for complete kits and found this one. just wondering if you guys have any advice on it. whether or not its a good kit and if you guys would advise any other over this. im looking for around 250-300 horse.
http://www.cxracing.com/mm5/merchant.mv ... ode=TRB240
WDRacing
smitty41393 wrote:Hey guys im lookin to turbo m for my ka24de . im looking around for complete kits and found this one. just wondering if you guys have any advice on it. whether or not its a good kit and if you guys would advise any other over this. im looking for around 250-300 horse.
This one is better.
http://www.cxracing.com/mm5/merchant.mv ... _Code=TOKT
The mani in your link blows and has fitment issues with the MBC.
WD
Elbowblk
Car: 95 240sx
yep as wd says it will cause the turbo to hit your brake master cylinder.
i bought that manifold with the intent to cut and reweld the flange for my toyota turbo. i put it in for s*** and giggles to see how the fitment was before i cut it. HORRIBLE.
if you do choose to get that kit. definately find a way to control fuel.
i know a local guy running a cxracing kit and its been good for him. but i have no idea what he had to modify, ect. if you do a search you'll see alot of ppl would consider it ebay junk. but then again it has worked flawless for some.
motoman399
Car: 98' wrecked (RHD coming soon) 240
WD that actually looks like a nice kit for the money but as posted you need something for fuel.
WD have you ever experimented with a 5th injector for extra fuel? i would be curious about that.
WDRacing
motoman399 wrote:WD that actually looks like a nice kit for the money but as posted you need something for fuel.
Dude...
I'm the man when it comes to sub-injection :dblthumb: There are tons of ways to run low boost without changing hardly anything in your stock setup. For instance, the cheapest way I've ever seen done that works well is adding a CSI (cold start injector) that is triggered by a hobbs switch. The CSI would come on at 5 psi and allow for 8 psi of boost without a tune or changing any other parts. The Dodge guys WAY back in the day used to do this all the time.
That's just a cheap method of adding fuel so you can run a low amount of boost. The methods for adding secondary fuel sources are almost limitless. Pick a target power level and there is a method for controlling fuel to get there without touching the stock system. Most are MAP based systems that control either solenoid pulses or fuel pump volume.
WD
motoman399
sweet. so say a car already had a cold start injector... just get a 5psi hobs switch and it then runs constant? that is pretty cool. i have an 88 celica that runs like a top.. and also has the cold start injector. plus i got a free turbo for it. but i was debating trying the injector idea or an fmu. cause i have both....
WDRacing
The FMU is a better option. Just use a 6:1 diaphragm for it, anything larger will make it to rich.
Lonismos14
Car: 1995 Nissan 240sx, 1999 Chevy Hoe, 1996 Saturn Sl2
Sell you my greddy kit. For 900+shipping and paypal fees. get some 550 injectors and you are golden. Efi specialist tune and everything
