compactfean »
https://forums.nicoclub.com/compactfean-u148941.html
Wed May 02, 2012 7:49 am
If you are planning on more than 500 hp the build will take a whole lot more then rods. If you have the money than do it but if you never plan on running more then pump gas, you won't have enough power to bend a rod anyways. Id spend my money on machining head and block so you can run a mls head gasket,.head studs, new rings, good main and rod bearings, cams, injectors, maf,.ecu and a tune. Also the turbo parts...... The stuff that will put you in the 400+ hp and all the accessories, gets very pricy, very quick. Just my o2.
