The application requires an Android device and an ELM327 OBD interface. The user can reset fluid counter and monitor fluid temperature and much more.
I used it on my Altima 2.5 SL 2010 and it is working very well. The application cost only a few dollars if you are already equipped with an Android device (phone, tablet). For people that do their own maintenance and want to reset their counter or adjust their fluid level at the proper temperature it is the perfect tool.
I found it on a Mitsubishi forum. I can’t post the URL here but if you do a search using Information about maintenance Outlander CVT (2014-2016) you will find it.
The post covers the threshold use to increment fluid counter. It also covers the replacement of the heat exchanger filter that is often neglected. This filter can reduce significantly fluid flow when restricted. Mitsubishi parts numbers are given for filter and oil seal. Same parts used for Nissan if equipped with the JF011E.
Hopes this help others with CVT maintenance.
Regards,
