CVT Versa in Snow - Throttle cutoff experience?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
williamk10
Car: '07 Nissan Versa SL
I didn't see this mentioned in any of the other snow threads. We got quite a bit of snow in Vancouver (about 10 inches). Has any owners experienced the Versa CVT cutting throttle automatically when stuck in the snow? I was stuck in an unplowed side street. While I was stuck, when I went over 3000 RPM without moving (slipping tires), the Versa automatically cut the throttle down to 2000 RPM and stayed there, no matter what I did, even at full throttle. Is this some sort of traction control? If it is, it is quite stupid as the wheels weren't even moving. I have to go from N to D back and forth to get the car rocking back and forth to get enough momentum to get out of the street.
Any other owners experience something similar?
blindsnyper
Car: 2007 versa
easy fix
williamk10
Or this
But I drove my Versa instead of my Discovery
blindsnyper
Car: 2007 versa
discovery+versa=disco/versa
tikus
Car: Rogue SL AWD Carbon Silver
If you read at your manual 5-19 this will tell you about CVT. This apply to Rogue with CVT.
Slither
I try to avoid spinning the wheels. I'd be going back/forth gently between L and R to try and get momentum going one way or the other.
SuperTurbo
Do what they say first, read the manual, and see what do the manual say!
I would recommend you to try to play around with the OD button, D&L position to see what have you find.
if your car basically will not move at all.... get a can of those cat sand, and put some in front of the wheels, and try it again....
Return to “Versa Technical Discussions”
