Transmission - Help needed
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
jjcp
Car: 06 versa
i recently get a problem, when pulling off the first gear takes longer than normal to change, after that all the others changes normal, its a cvt, i have the o6 model, i wondering wat cud cause this? could it be the fluid? i never change the fluid before and have the car a year now,
thanks in advance for the help
Atx_Versa
Car: 2008 Nissa Versa SL
jjcp wrote:i recently get a problem, when pulling off the first gear takes longer than normal to change, after that all the others changes normal, its a cvt, i have the o6 model, i wondering wat cud cause this? could it be the fluid? i never change the fluid before and have the car a year now,
Thats b/c the CVT will NEVER shift...I'm going to go out on a limb and say you have an auto vs. the CVT.
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
The auto trans requires fluid changes at every 30,000 miles. CVT has a computer to tell you when to change it. It should turn on the MIL light.
jjcp
Car: 06 versa
on the trans dip stick, it marks ns2 fluid only, which is a cvt transmission fluid, thats how i know its a cvt
jjcp
Car: 06 versa
after doing some research, it look like i have a auto transmission and not a cvt as i thought first, but i want to find out what could cause the first gear to take longer than normal to change
Promise Land
2001 Chevy Suburban
1992 Ford Mustang
how many miles on the car? if over 30,000, has the transmission fluid been changed? Worn fluid will make the transmission run a little odd because the transmission shifts based on a fluid pressure reading. if the fluid has been broken down by age and use, it will affect the shifting. You may be only noticing 1st gear, but all gears are probably a little affected.
jjcp
Car: 06 versa
i was advised to change the tran, because the first gear drag longer than normal to go into second and second gear slips into third, when driving the car hard the gears changes normal, but if u driving normal u get the problems, so its best i just change the tran and done worrying about it
Return to “Versa Technical Discussions”
