CVT transmission on the FX35??
A forum for lovers of Infiniti's hot-rod crossover, the FX! In 2014, all FX models will be named Infiniti QX70, in line with Infiniti's new naming structure.
hangout
Car: 2007 FX35,, 2016 Q70L
I just bought the 2003 FX35 sport package with 34k miles..
I'm thinking to change the transmission fluid on the car.. so, is it the CVT or a 4 spd ?which type of fluid I should get? please let me know..
Thank you
azfx35
Car: '07 FX35
You have a 5 spd automatic. Regular auto trans fluid should work. You can ask an Infinity srevice dept to make sure even if you do your own work.
hangout
Thank you very much
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
The FX does indeed use a 5 speed automatic common to the FM platform. This is the Jatco RE5R05A and uses Nissan Matic-S transmission fluid and nothing else. Damage can and does occur from using conventional fluid. If you are planning to drain and refill then you should get buy with 4 quarts but most dealers offer a full exchange using a dedicated Nissan Matic-S machine. This prevents possible contamination and is the proper way to perform this maintenance item.
It may cost a little more but the piece of mind and service records (in the unlikely event that something goes wrong) to get action from the dealer.
Return to “Infiniti FX35 / FX45 / FX37 / FX50 / QX70 Forum”
