cvt transmission noisy when cold
nysrogue
Car: 2009 rogue
i am a new rogue owner (2009, three weeks old)...traded my o4 maxima se...the cvt transmission seems to be noisy when cold and while driving around town...i don't know if this is normal or what noises i should be listening for with this type of transmission...very different than the 5at in my max...thanks for any info on this...
Leo2005
Every transmission would make a noise when its cold but cvt probably makes a it a louder or in a different way so you trying to find as a problem. You have to let the car warm up even in a hot weather I guess for 10-15 sec before starting to move. Also a good thing for the car is to turn the key to ignition for about 3-4 sec before starting up the car so gas pump start working before engine starts.
kerrton
Car: 2008 Nissan Rogue SL FWD Gotham Gray
I don't think the CVT transmission makes any abnormal noise at all. The noise you are describing is coming from the engine. Check our the LONG thread on the QR25 engine which is noisy when cold and under hard acceleration . The CVT in my experience is virtually silent, the engine is noisy.
nysrogue
Car: 2009 rogue
thanks for the info, didn't know what i was hearing...coming from the v6 max to the i4 rogue may be the answer...i will check out the engine thread...
philipa_240sx
Engine tapping or clicking noise when cold thread.
nysrogue
Car: 2009 rogue
thank you for the thread link...
Return to “Rogue Forum”
