CVT Tansmission
gwhibbs
Car: 2007 SL, CVT, Black
What preventative maintenance is required for the CVT. Fluid change? Does the belt require changing, and when? I looked through the maintenance manual, but am still not clear.
BBISHOPPCM
Car: '06 Nissan Murano S AWD w/ Convenience Pkg
The only maintenance required on the CVT is regular (30,000 mile) fluid changes. The fluid can only be changed at the dealer, as it does not use standard ATF.
Bubs daddy
Car: 2007 Nissan Versa SL
ABS, CVT
You can change the fluid yourself but the manual demands you use Nissan CVT fluid NS-2.
