CoupeVQ35CVT wrote:
You guys sure it's the TCS? I've had it engage when making a sharp hard turn under power, but that ALWAYS causes the computer to blip the throttle to prevent wheel spin and you can tell it's the TCS system doing that, while my foot is still on the gas...the light flashes too.
If the slippage happened while you could hear the engine still revving continuously during that time - that is not TCS I think, so who knows.
It happened again, twice in the same night here. I was actually trying to do some performance testing with my Bullydog turner, 0-60 times and such and I punched it and around 40-50 all I felt was kind of a drop in speed while still revving. I'd lift my foot up and it'd go down in speed more, put my foot back on the gas and it'd go a little more while still having the feeling of it dropping.
Then I did it again, going normal speed to 20ish then hitting the gas, letting off and hitting the gas again and the same thing as above happened. So I'm taking it into the dealer tomorrow and talking to them.
The only other thing I could think of is that could this be something to do with the +timing feature that Bullydog has? I have it set for +2 and I began to think that this wasn't happening prior to having it set at +2. Thoughts?
